Farmall Super A magne to vs distributor 12 volt conversion
Russ Crawford
09-16-2007 08:57:59
I am restoring a Farmall Super A. I have two questions. 1) the tractor currently has a distributor I am thinking of changing to a mag . Will a mag from a modelB fit? Is this a good Idea? 2) The tractor has been converted to 12 Volt. I an not sure it was done correctly. Where can I get detailed instructions on how to change from 6 to 12 volt system. Any help will be appreciated Thanks Russ
Janicholson
09-16-2007 12:26:59
 Re: Farmall Super A magne to vs distributor 12 volt convers in reply to Russ Crawford, 09-16-2007 08:57:59
The Mag will fit. The distributor will provide better running and idling because it controls the timing as a function of RPM. The Mag will however start the tractor without a battery. Remember if you use the mag, it is not connected in any way to the electrical system. The ignition On OFF switch is not interchangeable between the Dist, and Mag. The one it has now provides power to the Coil when out, and is open when in. If it is changed to a mag. The On Off switch is a grounding switch that grounds the mag to stop the tractor when pushed in. good luck, JimN
Russ Crawford
09-16-2007 12:38:33
 Re: Farmall Super A magne to vs distributor 12 volt convers in reply to Janicholson, 09-16-2007 12:26:59
Jim, Thanks for your help The wiring diagram is a great help. I think I will stay with the dist. Thanks again Russ
