Farmall H ?'s
Minnesotan H
09-16-2007 20:05:42
I am in the process of restoring a '43 H. The previous owner did some "micky mouse" wiring of things and I am trying to get it back in working order. I want to get things back to normal wiring and get it right the first time. Most of the wiring is severely weathered and cracked, so it's all coming off and starting fresh. I am trying to find some sort of schematic of the wiring for this tractor. I bought a shop manual from a local dealer, but not electrical information was available. Is there any manual/book/website that I can get to obtain this information? Thanks
Mike CA
09-16-2007 20:38:26
 Re: Farmall H ?'s in reply to Minnesotan H, 09-16-2007 20:05:42
I don't know what kind of restoration you are doing, but if you are doing show quality, then YT has the orignial cloth wiring harnesses.
Link
Scroll down to the bottom of the electrical system stuff and you will see them. Not cheap, but takes the guess work out of them.
Andy Motteberg
09-16-2007 20:09:04
Here is a link to Bob M's wiring diagrams. Find the one for your H. You can print it off too if you want. I am also restoring a 1943 Farmall H, I'm cleaning and sanding the tractor because I'm going to paint it soon. Good luck with your 43 H.
Andy Motteberg
Detroit Lakes, MN.
Minnesotan H
09-16-2007 20:22:47
 Re: Farmall H ?'s in reply to Andy Motteberg, 09-16-2007 20:09:04
thank you, that is exactly what I was looking for.
Good luck to you on your project.
