Farmall B Govenor bearings for block and end shaft
Gerald Peterson
09-17-2007 20:18:45
Does anyone know of a source for the govenor bearings?
Are there bearings that fit with some minor modifications that would work?
I have a 1947 B cultivision.
Thanks for your HELP!!!!
Jerry
gene bender
09-18-2007 03:29:31
 Re: Farmall B Govenor bearings for block and end shaft in reply to Gerald Peterson, 09-17-2007 20:18:45
Do you mean the bushing in the block where the gov gear goes or the three piece little bearing that goes on the shaft where the weights push. They are both avail. If you cant find one i can send you one as i get them from my I-H dealer.
ScottyHOMEy
09-17-2007 20:51:01
I'm not sure rom yourdescription just what you're looking for, but start with your neares CaseIH dealer. They still stock the thrust bearing and other parts.
