Generator belt
flashback
09-17-2007 20:45:29
What size belt needed for Farmall A generator and how is the easiest way to get it on.
Hugh MacKay
09-18-2007 03:26:47
 Re: Generator belt in reply to flashback, 09-17-2007 20:45:29
I was going to respond, however I can't improve on what gene has said, other than you may utter a few more 4 letter words than gene has indicated, before your finished.
gene bender
09-18-2007 03:18:36
This is no fun. Loosen up the fan the nut on the back next to the block is not supposed to turn in stead put a wrench on the spot next to the fan and loosen it. Now move the fan assy down as far as it will go then you can get the fan belt off the pulley then you can get get the gen belt out. You need a 17/32 wide by 26 1/2 long belt for the gen. You mite want to replace the fan belt at the same time then your belt problems will be good for many many yrs. It will help to remove the hood as it gives more room to work. You will have to remove the gen belt off the fan one blade at a time.
