66/86 series hydraulic couplers
K.B.-826
09-17-2007 21:27:56
Anyone know if there's a kit to convert from the IH female recepticals to the ISO style couplers? Kind of tired of using the adapters, since you really can't couple with the hoses under pressure when the adapters are plugged in. If there is a kit, does it eliminate the little latching levers like on the 88 series coupler? I somtimes have trouble getting the hose tips latched the first time on the 88 series style, which is why I wouldn't want to eliminate those latching levers.
minnesota red
09-18-2007 04:52:23
 Re: 66/86 series hydraulic couplers in reply to K.B.-826, 09-17-2007 21:27:56
i will look this after noon,but i believe our 5088 has 10 series magnum breakways on it.
i know out 1086 had ISO ports instead of IH ends.
IaGary
09-18-2007 03:58:47
Only kit I have seen and used eliminates the locking levers.
I just bought a kit this summer to switch the other 1086 over to ISO.
Now both 1086s ,the 1066 and the MX200 all have ISO.
I got tired of messing with the adapters also.
You need a pair or two of the adapters?(:~})
Gary
georgeky
09-17-2007 22:15:32
My 666 has pioneer couplers on it. Just push or pull. They work good.
w gatewood
09-18-2007 04:06:58
 Re: 66/86 series hydraulic couplers in reply to georgeky, 09-17-2007 22:15:32
a friend of mine just ordered 3 sets yesterday from case ih . they are around 120.00 a set
Mark in C.C.
09-18-2007 18:36:54
 Re: 66/86 series hydraulic couplers in reply to w gatewood, 09-18-2007 04:06:58
I had the dealer install those kits in the 686 I bought in july. They really work well and look good too. All my other tractors and implements are ISO so it makes things much more conveinient.
