Farmall 230 slow hydraulics
Chad Hurta
09-18-2007 22:53:14
My 230 hyraulics is slow to pick up and was wondering if there is a filter on that system. I believe my 200 has a filter but this is a diffrent type of hydraulics compared to me 200. Any info. would be appreciated.
Thanks
PaulW_NJ
09-20-2007 04:49:49
 Re: Farmall 230 slow hydraulics in reply to Chad Hurta, 09-18-2007 22:53:14
If you go to caseih.com, and follow thru to the parts section, and indicate model 230, you will find a parts blowups for your tractor. Look at page 258 and you will find the filter screen. Your system is identical to my 240"s. There is a cartridge within a metal screen. Hope that is the problem.
Chad Hurta
09-19-2007 20:29:54
Thanks for the info. It is a Hydra touch hydraulic system. I will check the screen on it. I did add oil to it when I first brought the tractor home it was low and had a small hair line crack in the hyraulic pump but had a spare and replaced that and now no leaks. Will you know how it goes. This tractor was an addition to my 200 and Super C. I have all two row equipment now for my garden and love to get out there and work with them. These tractor's are great for the garden.
Chad
homard
09-19-2007 05:33:05
Did you check your fluid level? You may be dangerously low.
What kind of hydraulic system do you have?
The 230 was available with two different types. One type was the "Touch Control". Look for rock shaft (arms that will rotate back and forth) under the gas tank. That is that same type of hydraulics found in the 200 and the Super C. There is a screen hydraulic filter that can be serviced (same size and shape found on the 200 and SC, look for a square plate with four bolts and may have a wire coming out of it going to a temperature indicator on the control quadrant). If cleaning that does not help there are some smaller filters and orifices within the unit that may need to be cleaned (the unit needs to be taken apart).
The second type of hydraulic system was the "Hydra Touch". That system is similar to what can be found on larger and later model Farmalls and Internationals. The "Hydra Touch" will not have the rocker arms. It may have one set of auxiliary service taps on the left side under the gas tank (not all Hydra Touch had the aux. svc"s). If you have a "Hydra Touch", there were two different types of screen "filters" (lower right side of support unit, ~3" square, with 4 bolts). One had just a fine metal screen that was servicable. The other type had a paper filter element that fit within the screen (again servicable but good luck finding a new filter of correct size). If you have the paper filter type, you might want to converting over to the metal screen type only. Either way, the Hydra Touch screens are the same shape but the screen is not the same shape as the Touch Control"s (not interchangeable).
IF cleaning the screens on the "Hydra Touch" does not help, the spool valve has a filter and orifice within it and the safety valve also which again means taking the whole thing apart...
Hugh MacKay
09-19-2007 01:20:26
Chad: Those systems use a screen, and I'm not exactly sure of 230 location. On the 200 it's just forward of battery near the bottom of touch control unit on left side, square plate with rounded edges and recessed cente, held in by 4 small bolts.
The 230 has the same type hydraulics as 300 and 350 yet those tractors used that same type screen as 200, in fact the 300 screen is almost same location as 200. I expect you'll fid the same type screen on a 230, and I'd be awfully surprised if it's not close to same location as on 200, 300, 350, 100, etc., etc.
