Breakthrough!
Mike CA
09-20-2007 20:14:34
I got through the ton of dried clay stuff in the sediment bowl top! I soaked it in carb cleaner for a day and pulled it out and drilled it out, scrubbed it out, and scraped it out any way I could. I got fluid to flow through it all the way.
So, back in for more soaking just to make sure I get it as cleaned out as possible. Now all I need is a gasket and it's good to go!
I'll eventually replace it with a duel line carb, but at least I don't have to spend money on this one to get it running.
Was there any sort of gasket at the shut-off lever? It seems a bit loose when I open it up to get fluid through it. I'm worried it will leak. Is it supposed to shake when opened up?
Mike CA
09-21-2007 13:36:46
 Re: Breakthrough! in reply to Mike CA, 09-20-2007 20:14:34
I sure am!
I'm getting a new gasket for it as well.
Mike CA
09-21-2007 07:12:40
Andy Martin said: I think you'll want a dual line sediment bowl assembly, not carburetor.
opps, I meant bowl, but wrote carb. I don't know why. third party image
Andy Martin
09-21-2007 06:17:33
I think you'll want a dual line sediment bowl assembly, not carburetor. The dual sediment bowl has a valve to switch between distillate and gasoline, with one line going to the carburetor.
D Slater
09-21-2007 02:34:06
Mike there's at least 2 types of packing nut types. Do you have the type that packing nut screws directly into bowl housing?
Bob Kerr
09-20-2007 20:38:49
I repaked the valve on my F-12 8 years ago with a neoprene O ring. Hasn"t leaked a drop since and the nut doesn"t have to be tight, just snug. O ring cost about 12 cents or so at a hardware store.
Mike CA
09-20-2007 20:26:09
I hear you guys, but I don't understand it. The valve is wobbly inside the casting. If I repack the nut, that will keep it tighter on the valve, but I don't see how it will make a bit of difference on the valve seated in the cast?
ScottyHOMEy
09-20-2007 20:42:19
 Re: Breakthrough! in reply to Mike CA, 09-20-2007 20:26:09
The casting is potmetal, the valve stem brass. It's going to be loose, very likely it was loose when new. What matters is that the tip of the screw mate reasonably with the seat in the body of the bowl. The packing will take care of the rest. It's not near so critical or touchy as needles and seats in a carb. Yes, it may have worn some, but repacking is an inexpensive first try at fixing your leak and, if it works, will last until the next guy starts to work on it, and save you the cost of a new sediment bowl.
GeneMO
09-21-2007 08:23:29
 Re: Breakthrough! in reply to ScottyHOMEy, 09-20-2007 20:42:19
I bought a new sediment bowl at Case IH about a year ago and I think it was close to $40.
So listen to these guys and try working with the packing if possible.
Gene
HENRY E NC
09-20-2007 20:22:08
Mike here should be a nut betweeb the lever and the bowl. Tighten it gently . if it is still loose use a little paking behind it. You can buy that at the hardware in plumbing Henry (thought all sailors knew how to pack a shaft) heh heh
ScottyHOMEy
09-20-2007 20:21:47
Sounds like the valve is a little wobbly. Not a gasket but what's called packing. Soft, flexible, ropy material, wound around the valve shaft under the packing nut. Were it mine, I'd rip/dig out all the old, rewind generously with new and tighten the nut down to where it turns snugly but manageably. Best part? Not costly.
