Order Farmall Cub Parts Online
cub pto lever to bushing(clutchdog)
GRIVV
09-21-2007 19:10:19
hello i had a 49 farmall cub i had to change the pto shifter the one that gose through the housing to the bushing are clutch dog wich puts the pto in and out of gear i took old one out but i can get the new one lined up is there some kind of trick to it i just cant get it lined up with the bushing when im going back in with pully shaft any help would be great thanks
GRIVV
Bigdog
09-22-2007 04:18:15
 Re: cub pto lever to bushing(clutchdog) in reply to GRIVV, 09-21-2007 19:10:19
If you have already secured the quadrant, loosen or remove it and it will give you a little more range of movement. Also, I find it easier to maneuver if the entire backplate is removed instead of just the pto shaft and bearing retainer.
GRIVV
09-22-2007 15:43:26
 Re: cub pto lever to bushing(clutchdog) in reply to Bigdog, 09-22-2007 04:18:15
is there anyway to line up the lil dogleg that gose through the housing that catch's the bushing to go in and out of gear i can get it all back togeather but i dont think its lining up right when i try to put it in gear it dose nothing. Its rainging now but i will try what you said about taking the whole plate off whe the rain stops.I just need to know how to get the bushing and the dogleg back in rightand lined up so it will go in and out of gear its a SOB (son of a booger) lol have a nice day and thanks for the help
ps:
i would like to add to this is a wonderful site for the do-it-yourselfer great site guys opps and ladys to ty ty ty and dose anyone know of any tractor shows near louisnan im near baton rouge and would like to start going to some if not to far again thanks for your help
