M carberator question?????
Eric Allen
09-22-2007 12:19:21
I'm trying to start up a early 40's M that's been sitting a long time and gas runs out of a small hole in the bottom of the carb. Would that be a drain in need of a bolt or is that maybe an overflow, meaning the float is stuck open? I don't know the maker of the carb but hopefully this sounds familiar to someone. Thanks
RustyFarmall
09-22-2007 14:06:38
 Re: M carberator question????? in reply to Eric Allen, 09-22-2007 12:19:21
Probably nothing wrong with either the float or the float valve. The most likely problem is that the float has rusted to the float hinge pin and is now in a "fixed" position.
If the tractor has been sitting for quite some time you will be time and money ahead to just pull the carb off, give it a thorough cleaning and rebuild it.
John S-B
09-22-2007 13:49:02
What Allen said, and they are kinda notorious for the float sticking on occaision. I always try to shut off the fuel when I shut it down.
Allan In NE
09-22-2007 12:34:18
Normally functions as an overflow for when ya choke it to much.
If the fuel runs out continually however, the float is stuck or the needle/seat is not shutting off the fuel inside the carb.
Allan
