Farmall 340 dash color (s)
Al L. in Wisc.
09-22-2007 12:27:32
My genny isn't so I have disassembled/cleaned it and need to get finer grained emery cloth to clean things up. Also need to replace rounded-head long genny bolt. Then, get some archive reading to check on what makes these things tick and why not mine. So...while making connections shiny, bright and tight I figured it a good time to replace all the gauges as none are IH. Thus my ? is: what was the correct color for the 340 dash and throttle control lever along with the little bolts and lock washers for the panel. 2:33 p.m. central daylight savings time and me thinks it is breakfast time. Thanks in advance for any input and I will check in later. As they say in the southern part of Norway...'ya'll enjoy ur day den'
bermuda ken
09-22-2007 18:49:00
 Re: Farmall 340 dash color (s) in reply to Al L. in Wisc., 09-22-2007 12:27:32
IH switched from Gun Metal Grey to Satin Black paint on the dash panels in June 1960. Check your serial number and paint it accordingly.
onefarmer
09-22-2007 18:54:26
 Re: Farmall 340 dash color (s) in reply to bermuda ken, 09-22-2007 18:49:00
That's good to know, with I knew when I was painting it.third party image
CNKS
09-22-2007 18:22:48
Early models were "gunmetal gray", which I interpret to be sort of a silver-gray color. Later models were satin black. I painted my 1958 460 dash sort of a silver color, not saying it is correct. I do not know what year the change occurred.
onefarmer
09-22-2007 18:08:48
I don't know what is correct, but I painted mine white like the rest of the trim.
