Farmall A drawbar question
flashback
09-24-2007 09:09:45
The parts catalogue lists a bolt 1/2 X 1 1/2 for the positioning bolt in the rear of the drawbar. They will not tighten so it is my observation that they are either not the right bolt or the threads are worn out. Comments requested on bolt size, threads or any other method of fastening the drawbar Thank you FOR YOUR ANSWERS
gene bender
09-24-2007 10:48:49
 Re: Farmall A drawbar question in reply to flashback, 09-24-2007 09:09:45
Better check the threads as most are stripped out not incommon for all the As and Bs. I go and tap them 9/16 and some times even have to go with 5/8.
ScottyHOMEy
09-24-2007 10:32:14
Those should be coarse-thread bolts. You're not trying to wind fines in are you? There should also be room for a lock washer under the head to take up a littel room, too.
flashback
09-24-2007 15:39:50
 Re: Farmall A drawbar question in reply to ScottyHOMEy, 09-24-2007 10:32:14
The thread is right. Since the hole in the drawbar is 1/2 then I will redrill it to 9/16 and tap the hole. I was thinking of filling the hole with JB Weld and then retapping it since there is no pull on it but I guess I will just go the new tap size. There is no
ScottyHOMEy
09-24-2007 19:13:29
 Re: Farmall A drawbar question in reply to flashback, 09-24-2007 15:39:50
Sounds like Gene hit in on the head. I got lucky on my BN and was able to salvage/use the threads there, but I can see how years of them being down in the mud and folks with a job to do forcing dirty threads could tear them up.
