Exhaust Lift Valve
DAVEB
09-25-2007 20:09:42
I have an exhaust lift valve casting # 5053EA
that I removed from a Farmall B. It is a control valve, not the one that goes on the exhaust manifold. It is in excellent condition.
Can anyone tell me what it is worth? Thanks
gene bender
09-26-2007 06:39:39
 Re: Exhaust Lift Valve in reply to DAVEB, 09-25-2007 20:09:42
It probably needs cleaned real good on the inside and a new rubber they are still avail from I-H. It may look good to you but unless you have experience with them it may not work under service. I sell them ready to work with all grease zerks taking grease and all chambers cleaned threads not worn on the lever new rubber seat for 35. I have tons of experience with the systems and are finishing up a restoration on a B-238 CULT with the lift will be used for parades and in the field.
csmeyers
09-26-2007 05:35:50
DAVEB said: (quoted from post at 20:09:42 09/25/07) I have an exhaust lift valve casting # 5053EA
I don't know what they are worth but I need one for my 1947 A. Once you determine what you want for it; that is if you are planning on selling it, let me know ASAP.
Thanx,
Corey
