#31 loader dimension
Ed Hotaling
09-26-2007 17:35:13
I have a #31 McCormick loader that a tree fell on, thank God it wasn't on the tractor at the time. It appears that the only damage is to the horizontal pipes between the top of the frame and the tops of the hydraulic cylinders. I know I can get these cut off of the end pieces and replaced, but I need to know the exact length they should be.
Thanks in advance,
Ed
chuck46
09-27-2007 16:27:52
 Re: #31 loader dimension in reply to Ed Hotaling, 09-26-2007 17:35:13
Hi Ed, It measures 82 inches between the center of the pins. Good luck, Chuck
Ed Hotaling
09-28-2007 14:45:04
 Re: #31 loader dimension in reply to chuck46, 09-27-2007 16:27:52
Thanks, Chuck. Once the insurance adjuster lets me get the mess cleaned up, I"ll be able to see if there is any other damage. I don"t think so and with the proper dimention, this should be easy to fix.
chuck46
09-26-2007 19:55:55
Hi Ed, I will get a measurement tomorrow and give you an answer by evening. Good luck, Chuck
