Farmall Grille , Burger and dessert!
Bob Kerr
09-26-2007 20:26:12
third party image
This was at the Elnora IN show. Cooks up front and freezes in the rear. Powered by a IH LA or LB engine and moves under its own power. Way neat!
Fancy Farm
09-27-2007 07:47:01
 Re: Farmall Grille , Burger and dessert! in reply to Bob Kerr, 09-26-2007 20:26:12
Sure would like some info on the ice cream freezor. I would like to make one to run off the belt pulley on my A farmall.
Bob Kerr
09-27-2007 08:23:28
 Re: Farmall Grille , Burger and dessert! in reply to Fancy Farm, 09-27-2007 07:47:01
They mounted the engine on the right side and had the engine shaft going to a pulley that went to the belt pulley shaft. The freezer ran off the belt pulley shaft with a slip coupler if I remember right. The belt from the engine had a idler pulley on it to put it in "neutral" and if you put the tractor in gear it would go where ever you steered it, but real slow. That is about all I can tell you about this one.
Mike CA
09-26-2007 21:55:52
Do you have any other pictures?
Bob Kerr
09-27-2007 06:11:40
 Re: Farmall Grille , Burger and dessert! in reply to Mike CA, 09-26-2007 21:55:52
I have a bunch more pics, and some of other grilles made out of two Hs! I didn"t want to clog up the board with pics so I will space them out some.
