Cab heater connections on a D-239
IH250
09-27-2007 18:44:52
Hi all just wondering if anyone knows where to hook the cab heater lines to on the engine?I have a D239 engine with a circulating tank heater hooked to the plug on the top right hand side water jacket and also to the block drain on the lower left side.Thanks in advance Jason
IH250
09-29-2007 18:17:19
 Re: Cab heater connections on a D-239 in reply to IH250, 09-27-2007 18:44:52
Looked over cooling system today and found a plug on the water pump.Does anyone know if I can hook the hot water line to this and the return to the block drain with a tee as I already have the circulating heater hooke to it? Thanks Jason
