super A 1946
t8erben
09-28-2007 14:03:59
I have no fire to the spark plug. It was running when I parked it a few months ago?
El Toro
09-29-2007 04:11:22
 Re: super A 1946 in reply to t8erben, 09-28-2007 14:03:59
If this tractor has a distributor you need to check for battery voltage at the coil. You should
include in your message whether you have a mag or distributor. Hal
El Toro
09-28-2007 16:25:35
You probably need to clean the points with a piece of 320 wet or dry. If they're pitted I would replace them. Hal
Hugh Mackay
09-28-2007 15:47:23
t8erben: If it's Super A it's not 1946, A prodution ended late 47 and Super A began production at that time. That part really doesn't affect your problem. Fire to plugs will be same on both.
What you probably should tell folks is whether it has magneto or distributor ignition.
