C301 block
Gearnut
09-28-2007 17:58:02
Gentleman...
I was at a pull a few weeks ago talking with a man who currently runs a V8 Nostalgia tractor (M with a V8). Prior to this, and for the last 30+ years, he has pulled many tractors including but not limited to IH"s with supercharged 301"s with superchargers. He even pulled with NTPA for a few years chasing points. I"m giving you this information because what I"m about to tell you came from this man"s mouth during a conversation we were having over 301"s.
He said the cylinder bore "thickness" is much thicker on a 301 and if I want to see for myself, he told me to pull a freeze plug out of a 301 and compare it with a 263 or 291. He said the outer wall (where the water touches) will be much closer to the outside of the block on a 301. He said you can put your finger in the freeze plug hole and tell the difference.
I find this absolutely amazing. And if I didn"t hear this from a man who has personally built many of these engines, and blown up quite a few, I would dismiss it as sheer nonsense.
My understanding has always been a 301 runs the piston right on the bore and sleeves are used to sleeve down to a 291, 282, 263, etc. So why on earth would the cyl wall be thicker on a 301 than a 291 or 263? .. or did they do it so they could be bored over a few times ?
Anyone ? Is he correct ? Thanks
the tractor vet
09-28-2007 21:05:46
 Re: C301 block in reply to Gearnut, 09-28-2007 17:58:02
Because when ya rebuild one of them ya have to BORE the block and put in a bigger piston then the walls get thinner and the next time it needs rebuilt they get even thinner till ya can't bore nomore then ya either sleeve it back to standard and start over or ya scrap it. Whereas on a sleeved engine ya just pull the wore out sleeve and stuff a new one in and ya don't have to haul the block to the machine shop for the boring .
Gearnut
09-29-2007 07:48:21
 Re: C301 block in reply to the tractor vet, 09-28-2007 21:05:46
Tractorvet, thanks for your reply. I completely understand the concept of boring-over vs sleeves.
But what I'm asking is do you have first hand personal knowledge of the topic at hand. ie: you've measured the wall thickness, or you have gone through some other measuring process to verify wall thickness (sonic testing for example) and have done the same on a 263 for comparison ?
And here's the reason I ask. If I were the engineer on the original casting, I would make all castings the same (say 3/8 wall thickness) and during final machining, machine the bore for a 301 and if it's a 291 or 263, either find a sleeve with a OD that matches the 301 bore or simply set the final bore to whatever the closest sleeve OD is available.
Given that, you could do the sleeve/piston replacement as often as needed, and bore the 301 once (.030) or twice (.060) before needing sleeves at some future rebuild.
Now it is possible they needed to "reduce" the casting wall thickness on a 263 for cooling reasons, ie: too much total thickness between the casting and the sleeve for the heat to transfer... and that could answer why (if it's true) a 263 has a smaller outside diameter cylinder casting.
Once again, I'm looking for "personal knowledge" on the subject and if your first reply was one of personal knowledge, just state the fact and I will thank you for your time and go look for a 301 block to bore out instead of wasting my time with a 263.
Mark
Thanks
the tractor vet
09-29-2007 08:15:49
 Re: C301 block in reply to Gearnut, 09-29-2007 07:48:21
Myself , no i have never done any sonic testing on the block . But i have done a bunch of 263 to 291 upgrades . Now this does require boring of the block and the use of a different sleeve as the 263 has a wide flange then a standard 291 sleeve . Myself i never cared much for a ag. engine that did not have sleeves just due to the fact of turnaround time on a rebuild . As sometimes a machine shop can mess ya up on a job . If the cranks mic'ed out good on teardown she got inchassed if not then the engine came out . As far as ever hopping one up never did even though i though about it sometimes but the 4 mains kept me from getting goofy with one.
GordoSD
09-28-2007 19:29:07
Which tractors have the 301?
Gordo
Gearnut
09-29-2007 14:59:39
 Re: C301 block in reply to GordoSD, 09-28-2007 19:29:07
To my limited knowledge, a C301 (gas) came in a 806 tractor and one or more different model combines.
