ih 460 utility loader
sam riccelli
09-29-2007 21:02:32
what loaders fit an ih utility
Gary in Mozarks
10-01-2007 09:32:04
 Re: ih 460 utility loader in reply to sam riccelli, 09-29-2007 21:02:32
Before you put a loader on a 460 utility make & install some side rails to tie the front end to the bell houseing. Otherwise you will break the front end off at the timeing cover.[/quote]
I have a older westendorf loader on my 460 Utility and it does have rails added to tie the front end to the bell housing
Ted in NE
10-01-2007 06:26:02
Janicholson
09-30-2007 08:42:54
That is a good question, but mighty broad. The problem is that almost any loader for a small/medium farm tractor can be made to fit. 50plus percent of the contributors here have no issue modifying and adapting hardware to fit a need. Most loader manufacturers make sizes and adapter kits to allow their units to be used on a cross section of similar sized tractors. so there may be some answers, but the best bet is to advertise your need (to left) and look for the right size in equipment yards and Bone yards. JimN
