is this a farmall H !!!
andi miller
09-30-2007 04:28:40
I bought a farmall H ,but the more i"m looking into it the distribitor is wrong. instead of being horizontal mine is vertical. its in the same place but vertical.did i really buy a "48 farmall h ,or something somebody has played with.
Andy Motteberg
10-01-2007 04:11:49
 Re: is this a farmall H !!! in reply to andi miller, 09-30-2007 04:28:40
The Vertical distributor is an aftermarket usually made by Delco Remy. It should also fit other makes and models of tractors. I once had one of those vertical ones on my H, but it was more difficult to time it, so I sold my distributor and bought a H4 magneto instead. The distributor sold for $101.00 and I paid $80.00 for my magneto.
IndianaRed
09-30-2007 16:20:44
Yep, my '42 is vertical too. I'm used to it.
STEWARTINPA
09-30-2007 06:19:40
I HAVE 1946 H IT HAS VERTICAL DISTRIBITOR RUNS GREAT SO I LEFT IT THAT WAY STEWART
Andrew Z
09-30-2007 05:29:12
Its most likely off a Allis Chamlmers, they used the verticle dist.
Andrew
tn terry t
09-30-2007 04:43:32
you probly have an h with a aftermarket distibitor
RustyFarmall
09-30-2007 04:42:27
Your tractor originally had a magneto ignition. At some point it was converted to battery ignition as most of them were, and the distributor of choice at that time was the Delco vertical distributor. There are probably just about as many Farmall Hs with the vertical distributor as there are with the IH horizontal distributor.
