FLUIDS
U101FREE
09-30-2007 13:10:20
i HAVE A 1959 , 601 FORD. THERE ARE THREE PLACES TO PUT FLUIDS IN. STARTING AT THE GEAR SHIFT DO i USE GEAR OIL OR HYDRAULIC FLUID? AND UNDER THE SEAT IS A RESEVOIR IS THET GEAR OIL OR HYDRAULIC FLUID AND LAST THE REAR END RESAVOIR IS THAT ALSO GEAR OIL OR HYDRAULIC OIL?
old
09-30-2007 13:49:04
 Re: FLUIDS in reply to U101FREE, 09-30-2007 13:10:20
Well other then your on the wrong forum heres how it goes. Front place you use 80W-90 or 80W-140 or hy=tran. center you use hyd oil or hy-tran and the rear the same as the front. The center area is the hyds on that tractor.
