O-T my walnut trees
Dave BN
09-30-2007 15:01:56
I have 4 black walnut trees that are about 15 years old and are about 20' tall. They have not produced any walnuts yet. How old should they be when they first produce? Dave.
Skinpine
10-01-2007 16:30:12
 Re: O-T my walnut trees in reply to Dave BN, 09-30-2007 15:01:56
Put a pound of zinc sulfate per tree, scattered in the drip area.
GeneMO
10-01-2007 05:14:53
Looks like the replies are all over the board as to time. I have approx 7 acres that I planted in rows in 1996. I mow between the rows. They are located in a creek bottom. We had a real late frost/freeze this past spring so I didn't expect anything. I started seeing a few scatterred nuts last year, and there a very few this year.
Gene
Dave BN
09-30-2007 20:39:04
Thanks for the info guys. Next time I'll ask you all how to keep the grape vines from climbing the trees in my swamp and killing them(the trees). You wouldn't believe the damage an over sized, over agressive grape vine can do! Dave
El Toro
10-01-2007 04:28:25
 Re: O-T my walnut trees in reply to Dave BN, 09-30-2007 20:39:04
Those wild grape vines killed a wild cherry tree behind me. Some of those vines were 30 or 40 feet
high. I take my loping shears and cut them then watch the vines turn brown from the sun. I would switch to pecan trees. I hated cracking those black walnuts. Hal
karl f
09-30-2007 22:56:29
steal those grapevines' dna and combine it with that of corn, cereal grains, vegetables, walnuts ;)...etc. and you will have super hero/villain crops. :D
karl f
Wayne Hendersen
09-30-2007 20:12:46
Quoting the shrewd old maxim from Jim in The Red Badge of Courage--"A Woman a Dog and a Walnut tree, the more you beat them, the better they be." While Jim wouldn"t win many nobel prize awards in the modern age - indeed he would be much more likely to be pilorized as the hapless victim of a media circus. Yet his advice concerning Walnut trees remains both sound and at least at this time, above prosecution.
In short, Walnut trees for some strange reason often need to be injured somehow before they will begin production unless you want to wait much longer than is neccessary. Just why this is so I am not entirely sure, yet aborists of old knew this to be the case and they would commonly strike the trunk with a large stick or strike them with an axe deep enough to go through the cambrium layer but not so deep as to structurely damage the supporting wood. If I were you this coming spring I"d give each of those trees a 3-4 minor nicks with an axe largely parallel and up to an angle of about 20 degrees or so out of the vertical with the trunk as opposed to horizontally. Do this approximately 2-4 feet high. I doubt at this point that it is going to do you any good for the year to come but the summer of "09 should see those trees start producing. My father in law has used this method with considerable success.
old
09-30-2007 16:07:33
I have a lot of them around my place and I have had nuts off trees that where less then 5 years old. So your problem is something other then the trees, a late forst will stop them from having nuts but so far I have never had a year yet that my trees don't bear.
Andrew Z
09-30-2007 16:19:31
 Re: O-T my walnut trees in reply to old, 09-30-2007 16:07:33
Walnuts will produce as as young as 5 to 10 years old on really good sites, but will not produce a viable crop till there at lest 25 year. DO the trees look helthy? and depends on your location in the U.S.
if you need more info try this link>Link
I>Link used this all the time in college. Andrew
Andrew Z
09-30-2007 15:10:05
Most Black walnuts start producing nuts around 30 years of age. This can depned on the site conditons as well.
Andrew
