conversion to 12 v
Pat-CT
09-30-2007 18:03:51
what will need need to be converted on my h to do a 12v conversion
neblinc
10-02-2007 07:55:16
 Re: conversion to 12 v in reply to Pat-CT, 09-30-2007 18:03:51
Fixed Hal's link, colon instead of semi-colon :wink:
Link
Randy
Kirby Boley
10-02-2007 04:15:43
There is aparts store in Mt. Plesant Ia. called T.H.E. Company that sells complete kits to
convert from 6v to 12v. Last time I checked kits were about $70.00. They are good to deal with and ship all over the country. Phone no.
319 385 3114. Hope it helps.
Pat-CT
09-30-2007 19:12:28
why is it a mayby need a regulator i have a brand new one but i doubt it will work for 12 v aslo i found this super tiny alternator that im going to use that should tuck under the sheet metal very nicely
El Toro
10-01-2007 04:04:08
 Re: conversion to 12 v in reply to Pat-CT, 09-30-2007 19:12:28
You may not need another regulator if your alternator has an internal regulator. Hal
PS: Here's Bob M's wiring diagrams web site.
http;//albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63226495&/=0
El Toro
09-30-2007 18:34:30
You would need an alternator or 12 volt generator,
may need a regulator, ballast resistor and a 12 volt battery. You would need 12 light bulbs too.
I'm sure I didn't cover all of the things. hal
terryjd
09-30-2007 18:50:35
 Re: conversion to 12 v in reply to El Toro, 09-30-2007 18:34:30
Not sure where they are located but there are some good wiring diagrams on how to wire a tractor for 12 volts. If nobody posts a link to them I can send you a couple of diagrams that I have here that I saved. If my SC gives me many more problems think it will be going 12 volt, think a bit more to changing the SC though from what I have read. Terry
