234 mounting brackets
Kirby Boley
10-01-2007 02:19:59
Could anyone tell me if brackets off of a super
M with a234 picker fit on a 400. No 2pt hitch
on the 400.
chuck46
10-01-2007 08:47:24
 Re: 234 mounting brackets in reply to Kirby Boley, 10-01-2007 02:19:59
Hi Kirby, Yes it will mount on with no changes, the bracket that mounts to the tractor belly has different holes for the M and the ones with TA. I have put mine on the MD or the 450D many times. Good luck, Chuck
georgeky
10-01-2007 07:45:58
They are different. The bracket for the SM is shorter than one for the 400 due to the TA.
chuck46
10-01-2007 08:59:22
 Re: 234 mounting brackets in reply to georgeky, 10-01-2007 07:45:58
Hi George, The bracket that bolts to the belly has 5 holes, just use different ones to compensate for the length. It is so wet here we cannot move with more rain forecast. Have a good day, Chuck
georgeky
10-01-2007 12:47:42
 Re: 234 mounting brackets in reply to chuck46, 10-01-2007 08:59:22
My mount for my NI picker will fit either one. Was told the 234 mount would not interchange, but I don't know for sure. The only 234 I ever fooled with was on an 806.
IaGary
10-01-2007 07:51:03
Yep george is right, forgot about the TA changing the length between axle and belly brackets.
Gary
IaGary
10-01-2007 05:24:39
I'm thinking they will.
Only got the belly bracted to worry about. But I beleive the holes are in the same place on the 400.
And if the axles housings are the same size, which I beleive they are, it should bolt right on.
Gary
