doing alot of work
Pat-CT
10-01-2007 06:55:25
making my h strictly for pulling so i ned you how to advise on a couple things 1 how hard is it to remvoe the hyraulic pump perminitly 2 where can i get a small 12 v alternator 3 how hard is to remove both ptos thanks for your input guys looking to get most of this done in the next couple of weeks
Pat-CT
10-01-2007 12:17:34
 Re: doing alot of work in reply to Pat-CT, 10-01-2007 06:55:25
im 16 im pretty good at fabing but i thought the hydraulic pump would be alot of work does anyone have a picture of what i have to unhook i rember there used to be pictures or a sight on what i have to do i just cant find it
Steven f/AZ
10-01-2007 13:04:02
 Re: doing alot of work in reply to Pat-CT, 10-01-2007 12:17:34
I believe it was KellyC who had a website detailing how to remove the belly pump...
Here"s a little help:
http://www.wimmark.com/liftall_replacement.htm
Steven f/AZ
10-01-2007 08:25:44
I"m assuming that you want to remove those items to save weight... right?
Making a plate to cover the openenings should be easy... if you have some basic fabrication skills. The rear PTO will just pull straight out once you get the bolts out - same with the belt pulley drive, straight up once the bolts are out.
Be careful lowering the hydraulic pump - it"s heavy! Just unhook the drive coupler and remove 4 bolts and it drops.
Andy Martin
10-01-2007 11:15:33
 Re: doing alot of work in reply to Steven f/AZ, 10-01-2007 08:25:44
Help my memory. I thought you couldn't get the coupling out without lowering the pump. Or is that only on an M?
I was concerned that because he described this as "doing a lot of work" that making covers would indeed be hard.
Steven f/AZ
10-01-2007 11:42:30
 Re: doing alot of work in reply to Andy Martin, 10-01-2007 11:15:33
The coupling will come out with the pump still in on an H.
Andy Martin
10-01-2007 11:13:26
Help my memory. I thought you couldn't get the coupling out without lowering the pump. Or is that onlu on an M?
El Toro
10-01-2007 07:39:52
I think Rusty Farmall recommended on another posting to disconnect the drive coupling on the hydraulic pump. Then leave the pump alone.
Any auto parts store should have alternators. I think the GMSI-10 is used a lot on this forum. Napa has Hytachi alternators. Hal
Andy Martin
10-01-2007 07:32:30
1 It is not hard to remove the hydraulic pump, just unbolt the control arm, remove filler and all the external pressure ports, then remove the sheet metal shield underneath (if it is there) then the four bolts on the bottom and it will fall out. You might want to sell it.
2 Auto parts stores sell Japanese alternators, research the archives. Why not just use a battery with no generator and keep the battery charged?
3 Removing the PTO and belt pulley are not hard, other than draining the fluid and refilling to get the PTO off. Fabricating plates to close the openings is hard. The belt pulley consumes no power until it is engaged and the PTO consumes very little. You will gain more hp by leaving the generator off than by removing the PTO.
