H throw out bearing
Andy Sommer
10-01-2007 07:23:06
I got the throw out bearing assembly out of my '44 Farmall H, however is the actual bearing pressed on the cast piece with the ears or is there a special way to remove them. Also there are two different bearings on YT and I am not sure which one it is. Thanks
Janicholson
10-01-2007 08:51:05
 Re: H throw out bearing in reply to Andy Sommer, 10-01-2007 07:23:06
Press fit. Use a good backer and a press to push it out. I can't ID your bearing without more info Numbers would define the issue. JimN
Andy Sommer
10-02-2007 08:23:55
 Re: H throw out bearing in reply to Janicholson, 10-01-2007 08:51:05
I pressed the bearing off, real easy. inside measurment is 2.056. Aetna ball and bearing company, outside measurement is 3.374. Thanks.
Andy
Andy Sommer
10-02-2007 02:04:16
I'll try to measure it in the AM. Thanks.
Andy
