1466 help
redman kyle
10-01-2007 09:02:42
i jus got a 1466 pretty cheap the motor was bad has a rod out the side so i repowerd it with a Dt466 now and jus got it running 2day everything works great except when i put it in 1st gear low side or high and let off the clutch it acts like there is nothing there! all the other gears work fine and no unnormal nosies i changed the hyd fluid before we started it cuz it looked like milk prolly from sittin a long time i knw that it sat for 5yrs in a shed before i got it but when i drained the fluid i found what looked like little needle bareings? i not sure but maybe thats my prob guess i start tearing it down.. any ideas?
RR Mech
10-01-2007 20:34:18
 Re: 1466 help in reply to redman kyle, 10-01-2007 09:02:42
I'm Sure that Jim has hit the nail on the head on this one. It is fairly common to have this happen. It ruins the front needle brg on the counter shaft and lets the rear of the shaft down so that first speed wont work. To fix you need to take the TA housing out of the tractor and overhaul it.
Jim J
10-01-2007 18:13:53
My guess is that the nut came off of the countershaft in the speed transmission. The way I diagnosis this is to pull the front plug below the constant mesh gear and look for needles out of the front needle bearing. Most of the time when this happens it don't hurt the housing
K.B.-826
10-01-2007 16:34:51
The problem with not being able to get first gear sounds like a linkage issue. Remove the cowling over the dash and inspect. The reverse idler is about the only thing I can think of off the top of my head that has needle bearings. On the left side of the range transmission, you'll see a large cover, held on by eight 1/2" bolts if memory serves me, remove that cover and you can inspect the idler.
randy hall
10-01-2007 12:18:10
lost needle bearings are most likely from the transmission countershaft.
Nat 2
10-01-2007 10:52:02
Check the linkages for excessive wear.
redih55
10-01-2007 10:01:29
Probably a safe bet to tear the trans down and
see what is wrong.
