MD stopped running
Tim Mylrea
10-01-2007 15:05:45
Traveling slow in 2nd gear and engine sound changed a bit, back fired through the exhaust and stoped running. Will not start on gas. Where is the best starting point to look for the problem?
Tim Mylrea
10-02-2007 12:04:21
 Re: MD stopped running in reply to Tim Mylrea, 10-01-2007 15:05:45
I pulled the valve cover off and the cam is not turning, but the rotor on the mag is. There seems to be a lot of valve clearence, 3/16 of an inch or better on the rockers that are open. How big of a job is it to replace cam gears if that is the problem and are the parts easy to find? Thanks Tim
Doc Larry
10-01-2007 19:35:55
I'm a bit confused. The MD is a gas start diesel. From what you said, this problem showed up when you were running on the diesel side. I think I'd pull the valve cover and take a look at the starting valve linkage and see if the valve timing is more or less correct.
Larry
Doug N
10-01-2007 15:21:23
Sounds like it jumped cam timing. Is it a mag or distibuter? Start by pulling the cap off, and tap it over to #1 compression and see if the rotor lines up with the #1 spark plug wire. If not, then you will have to pull the front of the motor apart to see what let loose. Doug N
Tim Mylrea
10-01-2007 19:09:44
 Re: MD stopped running in reply to Doug N, 10-01-2007 15:21:23
I am afaid that it is something like that, when you try to start it you can hear it blowing in the air cleaner. It has a mag. Thanks Tim
Doug N
10-02-2007 00:45:19
 Re: MD stopped running in reply to Tim Mylrea, 10-01-2007 19:09:44
Yeah, if you can hear it in the air cleaner, then something let loose. Good luck with it. Doug N
