BC-144 timing
markiz41
10-02-2007 05:53:16
Can anybody with the specs for this engine please look up what the advance timing light should be set to? Trying to get 'er to run right after rebuilding the distributor. Much appreciate any help.
Bob
10-02-2007 08:28:23
 Re: BC-144 timing in reply to markiz41, 10-02-2007 05:53:16
Is this the 144 CID gasoline engine used in the "B-414" and "354" tractors?
IF SO, the I&T manual shows full addvance of 39 degrees @ 2200 RPM's.
markiz41
10-02-2007 09:04:25
 Re: BC-144 timing in reply to Bob, 10-02-2007 08:28:23
Thank you, Bob. Yes, that'd be the one. In my case, it's inside a 3414 backhoe.
