Farmall H with a miss
dan.160
10-02-2007 13:31:30
I can"t get it to stop missing. There was charring on the cap and roter (no hot enought spark??). I replace new cap/roter and cleaned/gapped points to .015" New plugs and coper wires. Took a used 12v coil off a Ford 881 I"m restoring and bypassed the resister block so 12v to the coil and distributer. RPM"s as low as 500 up to 2100. Good power...just misses. What am I missing.
dan160
10-03-2007 03:47:22
 Re: Farmall H with a miss in reply to dan.160, 10-02-2007 13:31:30
Thank you all for the help!!! For sure I'll check continuity! The charring was mostly on the roter and I cleaned the cap w/out recalling what point in cap was mostly charred. I will look for compresion tester, have old kind (rubber boot you must hold and push on-not threaded on).
The gapping supprised me. I'll open up to .020" on the points and the plugs should be what then? I think I gapped plugs at .025-.028" ???Can't remember now.
Thanks again, Dan
Brownie450
10-02-2007 19:04:38
Where was the charring at in the cap & rotor? If it is only on one cylinder that is charred, the spark is not getting from the rotor to the spark plug on that cylinder. Check continuity from inside the cap through the sparkplug wire to the plug.
Brownie450
10-02-2007 19:07:21
 Re: Farmall H with a miss in reply to Brownie450, 10-02-2007 19:04:38
Check also for a crack on the inside of the dist. cap. Outside also. Sorry for forgetting in first post.
T.B.W.
10-02-2007 16:00:20
Had the same problem with a M. Put a new distributer in and it runs like a top. Steelwheel ranch got me a new one
larrystg2
10-02-2007 14:08:45
I think you should try a compression check. If you have a dead cylinder it will act like a miss.
Janicholson
10-02-2007 13:39:28
Gap is .020" not5 15.
Make sure the shaft has no play in it side to side. if it does, it will not run correctly. Wires are:
2-1
4-3
When looking toward front of tractor and cap is on.
If misfire persists, pull off one wire at a time to find the mis, then change the plug to a different cylinder to see if the mis follows the plug. If so get a new one. If not check compression, and valve adjustment. JimN
