RE DISTRIBUTOR IH
JAMES T DUNCAN
10-03-2007 13:14:11
HAVE OLD IH TRACTOR NOT SURE WAT YEAR IT IS HAS CAST #353898R1 4 CYL GAS GEAR DRIVEN NEED PARTS TO REBUILD ONE OR FIND A REBUILT ONE OR GOOD USED ONE MY SHAFT IS WORE OUT AND SO IS BOTTOM GEAR HAS 32 TEETH APPROX 5 INCH OVER ALL DIST LENGTH FROM BOTTOM OF SHAFT TO TOP OF DIST WITH NO CAP GEAR IS HALF INCH THICK 1 INCH ACROSS NEED HELP FROM SOMEWHERE
El Toro
10-03-2007 18:27:16
 Re: RE DISTRIBUTOR IH in reply to JAMES T DUNCAN, 10-03-2007 13:14:11
You will need to bring No1 piston to TDC on the compression stroke so you can time the distributor
to the engine whenever you get the parts you need.
Hal
D Slater
10-03-2007 18:01:10
Thats a distributor housing # thats used on letter series and later, very common. The distributor code and # are located on the outside of mounting flange where the 2 clamps go that you losen to adjust timing. Should be able to find a distributor or used parts easy. If you get another shaft, check the # stamped on rotor part to see if it matches yours. If not the total advance will be different. If no match make the replacement shaft advance limit hole the same by enlarging if smaller or filling hole and resize if larger, or carfuly drilling the correct size hole 180 degrees from original hole. The 32 teeth gear is common also.
JAMES T DUNCAN
10-04-2007 07:53:22
 Re: RE DISTRIBUTOR IH in reply to D Slater, 10-03-2007 18:01:10
THIS IS ALL I COULD FIND ON THE SIDE NOT SURE TURNS CLOCKWISE AND HAS EITHER 10S OR 1CS OR 15S CANT TELL WAT MODEL TRACTORS WOOD FIT THIS ???
Owen Aaland
10-03-2007 20:02:38
There will be a number and a letter on the plate. The number is the degrees of advance. The letter is either L or R fot right or left hand rotation.
NDS
10-03-2007 15:14:12
Distributor shaft for most 4 cylinder IH tractor engines is available on this site just click tractor parts on left at top of screen.
JAMES T DUNCAN
10-03-2007 15:33:48
 Re: RE DISTRIBUTOR IH in reply to NDS, 10-03-2007 15:14:12
I CALLED EM THEY SAID HAVE NO PARTS THAT I NEED SHAFT AND GEAR NOT AVAILABLE MY SHAFT ALL WORE OUT AND BUSHINGS
El Toro
10-03-2007 13:50:04
Which model is it? Hal
JAMES T DUNCAN
10-03-2007 15:31:21
 Re: RE DISTRIBUTOR IH in reply to El Toro, 10-03-2007 13:50:04
WE THINK IT IS A 544 ANY HELP WOULD BE APPRICIATED
