3 point hitch for I H 560
Jim De Moss
10-03-2007 19:29:37
Hi; Is there any one out there that can help me with a 3 point hitch convertion? Thanks.
Matt_In_Michigan
10-04-2007 18:45:11
 Re: 3 point hitch for I H 560 in reply to Jim De Moss, 10-03-2007 19:29:37
I don't care for my 3 point. I prefer my fasthitch.
Just my 2 cents.
Carden
10-04-2007 05:49:03
If what you"re looking for is a complete 3-point hitch, Saginaw is a great one. I bought one for my M and love it. It has dual Rams, can be setup 2 way and is a very well made hitch. It can be used with your drawbar on the tractor or without. Just my 3 cents...
Carden
Lee in Iowa
10-03-2007 20:27:29
You can buy conversion kits from many sources, including this site. Also complete three points if you don't have a fast hitch. I once saw a 560 on a sale that had had the lower part of the fast hitch removed and three point arms attached to the bottom of the brackets behind the axle housing that hold the rockshaft for the fast hitch. They used the fast hitch rockshaft, cylinder, and upper lift arms to operate the three point. With this setup you would have to use a cross drawbar or fabricate a swinging drawbar for drawn implements. Lee
Wardner
10-03-2007 20:27:23
We need some help here. Are you looking for a source new or used? Or, are you looking for installation advise?
You mentioned "conversion". Do you already have a two point hitch on the tractor?
