12 volt bulbs
billde
10-04-2007 05:26:52
I'm using 1143 bulbs and would like more light, is there a higher wattage bulb available?
Bob M
10-04-2007 07:03:44
 Re: 12 volt bulbs in reply to billde, 10-04-2007 05:26:52
The 1156 automobile backup lamp bulb will work. The bulb shape is slightly different but it fits, and it is marginally brighter (27 watts, vs 24 watts for the 1143). It's also cheap and available EVERYWHERE.
If you want something brighter go to an 1195 bulb (rated for 37 watts). You may have to order it online however - not all parts places carry the 1195.
Incidentally if you go the the 1195 or equivalent, Jim's advice below regarding the light switch dimming resistor should be followed!
Suggestion: Before messing around installing with higher wattage lamps make sure the lighting wiring, light switch, lamp sockets, etc. are also in good shape. Pay particular attention to lampholder grounding - often dim lights are the result of poor grounding.
RustyFarmall
10-04-2007 08:17:08
 Re: 12 volt bulbs in reply to Bob M, 10-04-2007 07:03:44
Not to long ago I found both the 6 volt and the 12 volt regular headlight bulbs at the local O'Reilly's. The local Case-IH dealer also keeps them.
Janicholson
10-04-2007 05:54:58
yes.
Any bulb that will fit behind the lense and have the common bayonet base. There are many. (there are archive numbers in -search for- above. It is important to avoid the use of the original light switch, or use a relay in the circuit to keep from overloading the dim resistor on the switch. Mounting seperate lights with a heavy duty switch, supplying it with amp meter voltage through a 15 amp inline fuse will also work.
JimN
