966 hydraulics
nemnjoe
10-04-2007 09:36:38
i was chopping corn when my auxillary hydraulics quit. everything else works except the 3 point and the auxillarys any ideas on what is wrong
the tractor vet
10-04-2007 10:11:19
 Re: 966 hydraulics in reply to nemnjoe, 10-04-2007 09:36:38
Could be ya sheared the Key on the hyd. pump . Drain the rearend and remove the hyd. pump and remove the gear that way you will know for sure. If this is not the problem then ya may have a stuck valve .
nemnjoe
10-04-2007 10:38:18
 Re: 966 hydraulics in reply to the tractor vet, 10-04-2007 10:11:19
thanks for the quick response tractorvet ill do that.
