question about painting
Pat-CT
10-04-2007 12:29:13
what is the best way to apint the engine im doing the tractor in steps and now im to te point where i want to paint the engine but whats the best way to strip it should i use oven cleaner or use a wire brush (which i was using for little parts but its kind of hard to get in there) also is there anyplace to buy paint online
dav_o
10-05-2007 11:18:15
 Re: question about painting in reply to Pat-CT, 10-04-2007 12:29:13
the other thing that works well to remove paint is aircraft stripper. be sure to wear rubber gloves, it will make your hands warm. and as for paint i like to use some " high dollar" paint on the sheet metal, the parts that really stand out. the old saying you get what you pay for is very true.good luck!!
Keith-OR
10-05-2007 11:34:05
 Re: question about painting in reply to dav_o, 10-05-2007 11:18:15
dav_o said: (quoted from post at 11:18:15 10/05/07) as for paint i like to use some " high dollar" paint on the sheet metal, the parts that really stand out. the old saying you get what you pay for is very true.good luck!!
I will not respond, no need.. third party image Pictures speak loader than words..third party image
just my 2 cents
Keith & Shawn (Special Olympic Champion)
Keith-OR
10-05-2007 09:49:25
I don't know which is the best way, I used a power washer and lye gravey, also cheap oven cleaner on tractor chasis. And anything that could be removed I put in my electrolysis tank, this was the way to go as it removed any and all paint AND also more important, the rust.
I haven't figured out why most everyone advocates using the HIGH dollar paint. As you can see from picture posted below I have the really high gloss wet looking finish from the standard CNH Iron Gard enamel $39 + pr gal. along with 5 star hardner at $18 pr pint. The depth of gloss depends on how much hardner you mix in your paint.HTH
PS..I have obtained just as good of results using $28 pr gallon paint from our farm supply using hardner
Just based on my experiences.
Pictures taken with overcast, (looks like it might rain today)
third party image
third party image
Andy Motteberg
10-05-2007 07:35:26
Use a wire brush, Drill wire brush, scrapers,& a sander. You can buy paint online, but if you have a place in town you can get it from, it would probably be a lot cheaper. I got DURA-SHIELD 4205 CaseIH Red Gloss paint for my H for $3.99 per spray can from L&M Fleet Supply. One can lasts for quite a while, but it is good to put on a few coats of it.
El Toro
10-04-2007 13:40:39
I would use name brand paint Martin Senour Crossfire or PPG's Omni Single Stage. Here's a SuperW6TA painted with Martin Senour's Crossfire.
third party image
third party image
ScottyHOMEy
10-04-2007 13:38:07
n a traqctor that I didn't completely dismantle, but needed to clean up to paind (or even work on for that matter) I started with a hot presssure washer, It did a fantastic job oif peeling away the heavy crud so that the other chemical and mechanicla stuff stod a better chance of wdoing what they were made to do.
Oven cleaner or flame both do well in loosening paint up so that a twisted wire wheel on an angle grinder. I've actuall got some paint on some whhelweights for a B that oven cleaner never sid get to the bottom of. Flame only left it tougher. Wound up griding it wdown and relied on the rough surface to hols the new paint on in the spots that I couldn't get cleaned off well.
old
10-04-2007 13:14:29
My self I get my paint from value bilt or at least I did on the last tractor I painted. No problems with shipping other then it has to go by way of ground shipping
georgeky
10-04-2007 12:45:53
I use an acetylene torch to strip paint off mine. Just heat until paint bubbles, then hit with a wire wheel and it looks like new. Oven cleaner works pretty good on oil and grease.
brainerd dave
10-04-2007 12:49:49
 Re: question about painting in reply to georgeky, 10-04-2007 12:45:53
I haven't found a place that would ship paint. Don't know if you can anymore. They consider it hazardous.
