farmall H starter
Askew
10-04-2007 17:01:39
I have had this H for a couple years now. When starting some times the bendex would kick in and some times not,it finaly quit kicking in at all and just spun.When I pulled it out the gear was worn at an angle. I put a new one in and it strats but is not kicking out and i can hear the gear grindeing.Any idea ?
Joshua Lawton
10-05-2007 12:48:23
 Re: farmall H starter in reply to Askew, 10-04-2007 17:01:39
Askew,
I had the same problem and it was the ring gear on the flywheel. If you pull out the starter, look in the hole in the housing with a flashlight and you can see the teeth. If you can turn the flywheel you will be able to see all of the teeth. Some of them may be chipped, worn, or missing. It's a relatively easy job to do if you have some mechanical aptitude and some special tools to split your tractor.
RustyFarmall
10-04-2007 18:21:30
Could be that you got some shims or spacers in the wrong place when you replaced that drive, or it could be that the starter ring gear on the flywheel needs to be replaced also. You'll have to split the tractor to gain access to the ring gear.
