no opening for starter on A housing
VA Gasman
10-04-2007 18:58:54
My son has an "A" with no openong in the bell housing for a starter. No lites. Nothing electrical other than magneto. Were there many of these made in this style? Is this one of the early models of the A ?
Thanks
gene bender
10-05-2007 03:10:17
 Re: no opening for starter on A housing in reply to VA Gasman, 10-04-2007 18:58:54
The one you are talking about is an early model. Later on they would install the bell housing for a starter whether or not it would leave the factory with a starter and just put a plate over the hole. Yours probably doesent have the flywheel machined for a ring gear either. So if you want a starter you will need to split the tractor of course but before doing mite want to look in the inspection hole on the bottom of your present bell housing to determine if the flywheel need changing also.
georgeky
10-04-2007 19:14:30
They came both ways. Some don't have it. I have one for the starter if you need one email me.
