farmall a tach?
charles p
10-05-2007 10:18:47
just got a '46 farmall a and she runs great. has no battery or generator and is hand crank start with mag. got a sickle mower for it but tractor don't have a tach. anyone know if i can put one on and where i'd get it from? thanks.
LenND
10-05-2007 13:53:13
 Re: farmall a tach? in reply to charles p, 10-05-2007 10:18:47
You don't need a tach. Start by running the engine full throttle and if the mower has too much vibration then adjust it slower until it runs smoother. Like was said keep the sickle sections sharp and should work fine.
scotty
10-05-2007 11:43:52
Afternoon Charles, One other thing, you dont need much RPM to run that sickle mower, the tractor can just kind of idle along and they cut great as long as its sharp !
scotty
Steven f/AZ
10-05-2007 10:50:08
Why do you need a tach?
Full throttle no load is about 570 rpm on my A, so I go to full throttle and pull back one notch for 540.
You could use a small engine type tach that has an inductive pickup from a spark plug wire - they are digital and also keep track of hours.
