Year Code Date
SproutW
10-05-2007 19:42:02
Anyone have the year code dates for casting numbers. I have a Q for a year date and wanted to know what year that is, thanks.
Andrew Z
10-05-2007 19:44:56
 Re: Year Code Date in reply to SproutW, 10-05-2007 19:42:02
1947, the numbers before that will tell the month and day, for example 10 5 Q would be October 5 1947 that peice was cast.
Andrew
SproutW
10-05-2007 20:00:57
 Re: Year Code Date in reply to Andrew Z, 10-05-2007 19:44:56
Thanks for the info. That means IH was still casting engine blocks for the F-20 in 1947. Who would have thought.
Andrew Z
10-05-2007 20:05:29
 Re: Year Code Date in reply to SproutW, 10-05-2007 20:00:57
No i think you have the wrong letter there better check that block again, should be over the letter "I" maybe its a "G" those cast letters are sometimes pretty hard to make out.
Andrew
Farmallgray
10-06-2007 11:42:06
 Re: Year Code Date in reply to Andrew Z, 10-05-2007 20:05:29
I saw an F-12 one time with an "R" casting code from 1948. I have never seen any other F-12s with date casting codes on the block.
SproutW
10-05-2007 22:06:04
This was an NOS engine block still in the crate. I'm sure it was made in 1947 because I have another block in a crate marked 1946.
