Will this oil pan fit?
Mike CA
10-06-2007 12:48:05
This is an oil pan off a '39 H. The plug looks different, and the only petcock doesn't look like the ones I have. Will I be able to swap the petcocks off my '44 H pan into this one? What about the drain plug?
third party image
D Slater
10-06-2007 16:56:38
 Re: Will this oil pan fit? in reply to Mike CA, 10-06-2007 12:48:05
That pan is from a later tractor, 39 would of ben a 3/4 inch pipe plug for drain.
RustyFarmall
10-06-2007 14:24:16
I think the drain plug is probably correct.
Those pet-cocks don't like to come out easily without getting the area around them re hot with a torch, and then you'll probably still leave marks on them from the pipe wrench. Not saying it can't be done, but it ain't easy.
