Oil filter gasket
Mike CA
10-06-2007 17:13:14
The gasket that came with the filter for my H sits neatly in the groove that the cover was snugged down in. Is the cover supposed to sit on top of that rubber gasket, or is the gasket the wrong size?
Where should the gasket go?
Mike CA
10-06-2007 18:33:03
 Re: Oil filter gasket in reply to Mike CA, 10-06-2007 17:13:14
At first I didn't understand what you meant, then it dawned on me... the old gasket is still in there! So I dug it out, replaced it and installed the filter!
Now I need an oil pan, oil pan gasket, and some oil!
Noah W
10-06-2007 17:24:43
It goes into the groove. If a new one comes with the new filter, use an icepick or an awl to dig the old one out and be sure to oil it up good before you put it in, and be sure it is properly seated. If not, CAREFULLY dig the old one out and turn it over. I've cut more than one when I tightened the cover down. They will leak if they are not seated.
