transmission gear
Murry
10-06-2007 18:42:07
Is the shaft, driving transmission (18 and 35 teeth) the same on a Farmall H and Super H?
I am rebuilding the transmission on a Super H.
r4etired
10-07-2007 08:07:12
 Re: transmission gear in reply to Murry, 10-06-2007 18:42:07
The H gears will work but they are about an 1/8in narrower than the SH
D Slater
10-06-2007 19:30:10
H serial # 391358 and higher is the same. You can use other H with the H input shaft bearing housing in a SH. Bearing strength will be a little less than SH. Stay away from real early H transmission parts.
