F11 Loader pump off front of Farmall Super M (live power)
Gerald Mansfiel
10-06-2007 20:16:16
I'm looking for information on how to connect my F11 Loader pump off the front of my tractor for live power. It's a Farmall Super M. I've been told it can be done. Want to know how to do it. Thanks in advance.
Gerry M
Allan In NE
10-07-2007 01:06:35
 Re: F11 Loader pump off front of Farmall Super M (live power in reply to Gerald Mansfield, 10-06-2007 20:16:16
Here's how I hooked up the F-11 and it just works great.
Don't know how you'd use the original Farmhand pump tho bcause it is designed to run off the PTO.
Allan
third party image
third party image
Gerald Mansfield
10-07-2007 05:16:51
 Re: F11 Loader pump off front of Farmall Super M (live power in reply to Allan In NE, 10-07-2007 01:06:35
Thank for the pictures. I'm have a set up similar to that but it feeds the power steering, three point, and two extra lines for a cylinder on the blade. I don't think it could handle the loader so I would like to use the front end of the engine by the starter crank.
Allan In NE
10-07-2007 08:07:18
 Re: F11 Loader pump off front of Farmall Super M (live power in reply to Gerald Mansfield, 10-07-2007 05:16:51
Sure it will.
You only use one function at a time anyway. Otherwise, that oil is just dumping to the tank during "inactive" times.
The power steering priority valve will rob from the loader a bit, but you get used to it and after a while don't even notice it.
Allan
Gerald Mansfield
10-08-2007 04:37:51
 Re: F11 Loader pump off front of Farmall Super M (live power in reply to Allan In NE, 10-07-2007 08:07:18
It's worth a try.
Thank you,
Gerry M
