Hey guys, what pistons are these? (M)
CenTexFarmall
10-06-2007 21:12:53
A short while back and with the help of DSlater and some others, I figured out that a '51 M of mine has some kind of replacement motor. It has a casting date of '59, "C-248" on the side and also the little plate that screws on the side of the block beneath the carb. Now, I did some investigating, took the plugs out and shined a bright light in there. I've got domed pistons, but not sure which ones and maybe you guys can help me figure that out.
Using a bent end scribe, I've determined that the dome is about .250 tall, also it has no gaps across the top of the dome, it's continuous. The quench side of the piston is flat. GeorgeKy had sent me a photo of some Firecraters and they're not like that. Also found some other photos by searching the archives and still no match. Judging by the photos, the domes don't seem to be as tall as the M&W turbo dome or some of the new aftermarket ones I've looked at. The dome does seem to be wider though.
The tractor has the X1B suffix, which makes it originally a 5000ft. altitude setup. Would a dealer have paid any attention to that when ordering a replacement motor? Or perhaps would it have been a replacement _block_ with someone building the rest from parts and putting in higher comp. pistons? Could all replacement motor in the later years have come with higher compression?
Charles E. McNelly III
10-07-2007 20:22:34
 Re: Hey guys, what pistons are these? (M) in reply to CenTexFarmall, 10-06-2007 21:12:53
If the dome is flat and is the shape of the combustion chamber, you probobly have the 5000" alt. pistons. I have the same pistons in my W-6. X1B- gas with 5000" alt pistons. Is your compression around 135 lbs? Charles
Steven f/AZ
10-07-2007 13:49:01
These are the pics I have of IH pistons, don't know if it will help or not:
Firecrater:
third party image
M&W Turbo Dome:
third party image
New Conformatic that I put in my H:
third party image
CenTexFarmall
10-07-2007 19:28:54
 Re: Hey guys, what pistons are these? (M) in reply to Steven f/AZ, 10-07-2007 13:49:01
Thanks for posting these. It is helpful to put a picture with a name. However, it is none of these. It looks to be a taller dome than the Firecrater but not as tall as the M&W. No slot though.
CenTexFarmall
10-07-2007 13:18:41
Ok, consensus so far is that these are some kind of "stepped head" piston. I'm not sure if these are aluminum or iron. There's a dimple in the end where they've been center drilled for machining but that probably doesn't mean anything as far as material.
If you can find that chart it might give some idea of possible compression ratios. I won't be able to get a picture up as I don't want to pull down a running motor.
What little I've run it, it seems to run good except for the governor hunting. It runs strong. The biggest problem for the tractor is transmission issues. I think it's in the shifting linkage. Right now I have first and reverse. It seems like it wants to go into two gears at once for the other speeds.
skk-big red fan
10-07-2007 12:47:12
I agree. Step head pistons, probably IH. I think they sound about right for the 5000 & 8,000 ft model engine (different height steps). There are after market step heads also.
To my knowledge, however there are far more experienced folks on the board in this area than I, but I believe that Fire Craters were an overhaul (performance upgrade item) made for IH by "Perfect Circle" as an accessory add on only. I have a chart here some place that I think would tell me. I don't think any H or M blocks came from the factory with Fire-Craters in them, not even the 8,000 ft or propane models.
Others have confirmed for me that the original "high compression" pistons were even made out of cast iron & not alum--and am sure they were a flat stepped only design.
Not sure what pistons were avl in the 300 thru 450 high compression models from the factory.
Pat-CT
10-07-2007 07:36:52
the only way i could see us helping you is if you get pics if the date it was cast is 59 theres no telling what block it has in it im stumped as to what it could have int it
randy hall
10-07-2007 05:30:41
sounds like your pistons are step-head. they could be ih or aftermarket.
