blow by in my 560 help!!
black dirt farm
10-07-2007 07:19:36
I have a 560 gas. I know the basics when it comes to the in side of the motor ??? I've been told I have blow bye. cuz gray smoke blows out the blow bye tube. can any one help me out so I don't get robed at the motor shop
Janicholson
10-07-2007 14:18:19
 Re: blow by in my 560 help!! in reply to black dirt farmer, 10-07-2007 07:19:36
I'm going to add to the great advice below that if it is not consuming more than a quart of oil in a days medium duty (more than a hay rake less than a mold board plow) it is probably tolerable. If the consumption is higher, or spikes at a quart every two-three hrs under full load, it is time. JimN
leroy in ne
10-07-2007 11:15:18
all engines will have some blow by visible from breather tube from that time frame. if excessive it indicates time for complete engine overhaul. How is this tractor used? if on light loads only it may be suffering from stuck rings or glazed rings. find a load to put on it that will pull the dog s*&t out of it these engines need to be worked to get cylinder and piston temps up and burn carbon build up out of it
the tractor vet
10-07-2007 08:21:05
IF ya have blowby then i would venture to say that she is suffern from internal injurys and either she is plum wore out of she started to seezen because of scoreing of liners or melted pistons due to incorrect ing. timing or improper fuel or just plum used tomuch when new. As for just putting rings in is like putting a bandaid on something that needs a dozen stitches.
black dirt farmer
10-08-2007 07:43:39
 Re: blow by in my 560 help!! in reply to the tractor vet, 10-07-2007 08:21:05
thanks for your reply. I love the tractor! I've got 3.000 in to it. it came with a loader
wide front, a narrow front,no three point I use the tractor for moven round bales, discen the feed plot and dragen timber out of the woods. Say I use the tractor for a day, four hours of running time it uses a qrt. how long can I keep this up or does this need to be addressed right away. re build kit what do I need for a parts list thanks for your help
r4etired
10-07-2007 08:00:25
I would check compression in each cylinder,could have a bad piston.
georgeky
10-07-2007 07:24:06
Usually means you need new piston rings. Sounds like it is time for an engine rebuild.
