Farmall A Piston Help
J-Green
10-07-2007 10:01:42
Should I go with overbore kit with stepped pistons Or standered flattop piston kit? What are my advantages with the stepped pistons or flattop?
ddg
10-07-2007 14:46:35
 Re: Farmall A Piston Help in reply to J-Green, 10-07-2007 10:01:42
I rebuilt my SA a couple of years ago, and wondered the same thing. I had the head planned enought to square it up, and had it completely rebuilt with new valves & guides. they re-ground the coutour on the rocker arms where they contacted the valve stems, and shimmed some of the springs. It got new valve seats too. Just like a new head. The pistons in mine were the old cast iron pistons with three upper & one lower ring. I went with the bigger bore and lighter aluminum step tops. I was worried about it being harder to crank, but it was not noticeable, it starts on the first lick now, never did that before. Enough power to mow tall grass in 3rd with the old Woods L59. Using whatever pump gas I want, and 10-30 oil. I also put in new main & rod bearings at the same time, runs like a new one maybe better. (1948 #250559)
El Toro
10-07-2007 11:36:13
third party image
I just went with the 3.125" overbore on my A. It has plenty of power to create wheel slippage with the 16-inch plow. Hal
Pat-CT
10-07-2007 10:28:21
advanages are more compression and ess compression steped heads give you more compression and flat heads dont
Pat-CT
10-07-2007 10:28:19
Janicholson
10-07-2007 10:26:10
Increasing the power of an A is nice, but not necessary. The increase to 123CID is easy, and the use of domed pistons will be even better. Efficiency is increased by increased compression, so total economy will be incrementally better. The use of unleaded regular fuels will be fine with the bigger bore and dome pistons. unless head shaving, and other specialty efforts raise the compression pressure above 155osi or so. JimN
