Vacuum leak
Tired 300 in Mn
10-07-2007 14:29:13
Just want to pass on a note of thanks for all the information on this forum. After cleaning gas tank & carburetor (both had considerable amounts of crud), I still had to use the choke after engine warmed up. I looked at the archives & found info on vacuum leaks. Yesterday, after my 300 was warm from an afternoon in the woods, I put a nozzle from a can of WD40 on a can of ether. The engine speeded up considerably when I sprayed at the front intake port gasket area. I will try to check manifold & head for straightness when I replace the gasket. Thanks again. Sonny
