2,000 rpm's
Walley Varner
10-07-2007 23:13:59
Can the Farmall A motor be run at 2,000 rpm's without doing damage?
Janicholson
10-08-2007 06:15:44
 Re: 2,000 rpm's in reply to Walley Varner, 10-07-2007 23:13:59
Hugh is correct.
If it has a fresh out of frame overhaul, and quality insert bearings on polished journals, and aluminum pistons, it will more than likely do well, However the cam, intake, and timing were designed for 15-1600 RPM. Cranking it higher will not radically change the peak torque RPM for heavy tillage, or real work. JimN
Hugh MacKay
10-08-2007 02:10:11
Walley: Depends on what you call damage. A Farmall A was good for about 4,000 hours between engine rebuilds running at 1,500 rpm. with thermosyphon cooling at 2,000 rpm, your probably looking at 2,000 hours between rebuilds.
flashback
10-09-2007 07:27:01
 Re: 2,000 rpm's in reply to Hugh MacKay, 10-08-2007 02:10:11
sounds like another person wanting to go faster. I am not sure why people buy an old tractor and want to change the operation of the machine ffrom normal. The tractor was deigned for maximum performance at ceertain ranges and geared that way also. Seems speed has filtered its way into our hobby .
