Farmall M Diesel Piston Removal
Maas
10-08-2007 07:22:30
Was Wondering With Engine In Tractor Whats The Correct Way In Removing Pistons So I Can Re RIng Them Also Can I Change Rod And Main Bearings On This MD With Just The Oil Pan Off?
Mike Farmer
10-15-2007 11:46:44
 Re: Farmall M Diesel Piston Removal in reply to Maas, 10-08-2007 07:22:30
You can channge the bearings but you won't be able to check the wear on the crankshaft,so you may just knock out a new set very quickly. If you think it needs doing then I guess your going to have to 'bite the bullet' and take the engine out. Luck! Mike Farmer
El Toro
10-08-2007 13:27:40
You will need to remove the ridge at the top of the sleeves with a ridge reamer or you may damage the piston. You need to measure the sleeves for wear too. Hal
georgeky
10-08-2007 08:05:47
Take off the head and oil pan. Then remove rod caps and push pistons out the top. Yeas you can renew bearings with pan off.
