Tractor swap
NICK KOEPPE
10-08-2007 19:25:10
I would like to know if I can take a motor out of a 1256 international and bolt it to a 560 international and if so. What would be some thing that i may want to look at and any help would be nice
ChadS
10-09-2007 06:00:46
 Re: Tractor swap in reply to NICK KOEPPE, 10-08-2007 19:25:10
NICK KOEPPE said: (quoted from post at 19:25:10 10/08/07) I would like to know if I can take a motor out of a 1256 international and bolt it to a 560 international and if so. What would be some thing that i may want to look at and any help would be nice
Been told a 361 out of a 806D will bolt right in using the 806 front frame on the 560 bellhousing. Possibly, the starters work,,, supposed to be close to, or the same specs as a 560,,, but the tooth count on the ring gear might be wrong, could be as simple as changing a starter, or??? Might have to look at the input slpins on the clutch disk, but, been told that it should bolt together. ChadS ChadS3@hotmail.com or www.thetractorshop.com
