Farmall 400 Governor problem
fasrmall 400
10-09-2007 01:57:11
I have a 55 Farmall 400 that runs as good as you could ever ask for, except at mid throttle the engine will suddenly speed up a few hundred rpm without warning. This seems to occur only when the tractor is at about 1/3 to 1/2 throttle, moving and is unloaded or loaded, even a moderate hill climb can cause it. Have I got governor problems? Any ideas? Thanks guys.
neblinc
10-09-2007 05:37:11
 Re: Farmall 400 Governor problem in reply to fasrmall 400, 10-09-2007 01:57:11
I am guessing here, but maybe worn/weak governor springs or the holes have worn oblong allowing the rpm change.
Randy
teddy52food
10-09-2007 06:08:53
 Re: Farmall 400 Governor problem in reply to neblinc, 10-09-2007 05:37:11
Also, the screws may be loose in the throttle plate. Check these before you have one on top of a piston.
